GRID IRON 52 (1xUAC5, 3xMLas, 1xAC2, STD200)
Thread in 'Grid Iron' started by KADOW, Jul 5, 2014.
  1. KADOW
    KADOW New Member
    Here is my build The Grid Iron 52 taking helpful feedback.
  2. Gemini106
    Gemini106 New Member
    Iwant to post this build here, but you were first! Fine! ;)
    I run it with 2 x MPL in the arms, this scares the scouts a bit more. Excelent 2nd line hunchback. I stay behind the fat guys and make a fine fire support. If some come close use MPL. In closed quarter combat he isn´t the best.
    this vid shows a lot
    For sure you have to use a std engine in a HBK
    For me the best working HBK GI!
    Hve fun with this KADOW!
    Rock´n Roll
  3. Auriga
    Auriga MechSpecs Addict
    599
    My thoughts: Too slow for a medium mech, and carrying the AC2 is more a burden than a help, for 2 more tons u can fit an AC5, a weapon that deals 2.5 times more dmg per shoot, and one of them could be the MLas in the hunch's arms, cause u loose that arm so often (with the hunch), that i have it empty in all my Hunchies, or downgrade it to an MG saving 6 tons, cause the rate of fire is quite similar if u are thinking in criticals.
    That being said, i think that this config is more efficient. Saved the MLas in the hunch's arm for you, but i hearthly suggest you to replace it with other thing, either upgrade the head MLas to MPLas, or get more ammo. Also u can change 1/2 ton MG ammo for one extra 1/2 ton of UAC5 ammo.
