All arounder type build that uses the dual LLas as the main damage source during the beginning of the match but also has good up close punch. When I support the firing line I will occasionally fire all the lasers together if the target is within 350-400 meters just for that extra damage from the MLas. The MLas also allows you to keep the pressure up when you're close to the max heat threshold. Weapon groups: 1: 2x LLAs 2: 1x Mlas 3: 3x SRM4 Twisting is extra important in this mech with all your weapons on the right side. Thankfully, I haven't had to much trouble defending . The SRM4s can also be directly traded for a trio of streaks and a BAP. EDIT: I'm having some luck with SRMs lately so I decided to lower the long range potential by trading one of the large lasers for a second medium laser, artemis and a ton of ammo for the SRMs.
