[FEEDBACK] Loup De Guerre Hero 'Mech Arrives on the Battlefield!
Thread in 'MechWarrior Online' started by Blagg Zear, May 20, 2014.
  1. Blagg Zear
    http://www.youtube.com/watch?v=argHjbXAO64​
  2. Excalibaard
    Looks like a pr4etty sexy thing tbh. 90 degree twist sucks, but 35 degree pitch is pretty awesome (hunchback has 20-25). Combined with arm-mounted direct fire and the possibility to mount streaks in the less maneuverable torso, I think the SHD-2D2 has a competing light-hunter.
    The 2d2 still looks much prettier though :X
  3. Blagg Zear
    I will buy this Hero, simply because of the awesome Skin-Artwork and btw it's in MY three prefered Skin-Colors!!! Wow!
  4. e92
    e92 Benefactor
    291
    With the SRM tweaks, I've noticed I've been getting hit HARD by them. I would probably load this like a jumping kintaro SRM boat. Should be very formidable!
    However, by inspection, I don't see any advantages over the 2D2 for the "light-hunter" 4xSSRM2 build.
    - Arm mounted streaks are pointless for streaks because target lock occurs on the arm reticle anyway. Plus, they can be knocked off
    - Missile tubes mounted lower means decreased ability to shoot overt short obstacles and hills
    - 5 less tons probably means its probably confined to 2xMLas build instead of 2xLLas
  5. Excalibaard
    In return you need a smaller engine for the same speed, haven't done the math (And I assume SHD are still superior), but as long as engine ratings above 300 are concerned, they ramp up really quick. XL325 has 4.5 tons over the XL300. And the XL300 only 1.5 over the XL275/XL280.
  6. Solahma
    It really is still... You can run the same build that I posted, same speed, same weapons, but there is more armor on the SHD...
    Blagg made a build that runs ~10kph faster than the SHD, but again less armor and 1 ton less ammo and slightly less heat efficient.
  7. Roosterfish
    Roosterfish Well-Known Member
    121
    I've nothing for or against this particular hero mech but I want to call it the Coup de Grace.
  8. Blagg Zear
    Can't compete with the epic Shadow Hawk. But if you want Quad Streaks in a 50tonner... well, there is no Alternative atm. ;)
  9. epikt
    It takes an XL280 to acheive similar speed to a SHD with an XL300, which unfortunately gives 3 less tons to work with.
    Most likely the Trebuchet will be less heat efficient.
  10. GDCarlyle
    GDCarlyle Junior Member
    Pardon if I am off-topic, but did ANYONE notice that @ 35 seconds, the Loup takes down... get this... a MAULER??!?!? Note the shark fin on the head and arms that don't match any other chassis.
    Just saying...
    EDIT* Or am I just seeing things?
  11. TalRavis
    TalRavis New Member
    I believe that is a Protector, ON1-P.
    Anyways, maybe this could make for a mildly decent missile boat. It's got 20 tubes all over.
  12. e92
    e92 Benefactor
    291
    Also, they did a damn good job with the video. I'm PUMPED!
  13. Excalibaard
    http://mwo.smurfy-net.de/mechlab#i=157&l=ab6381bf2d48921a0b2bb677316452ed4917def7
    http://mwo.smurfy-net.de/mechlab#i=111&l=194b5db07e1799a58a718130d327c998d27ea99f
    Yep, SHD beats it, if you get the XL330 instead you'll be running just as quick with spare tonnage for armor or DHS or something. :D
    I find it hard to imagine you can actually use those 20 tubes effectively. If you have this many hardpoints and so little tonnage, it's better to run 2x10 instead, or even 2x10+2x5, which is what I'm planning to do on kintaro's (and already proven in stalkers).
  14. RNIntegrity
    RNIntegrity Active Member
    85
    I've never owned a Trebuchet before and don't intend to start now but the video was amazing.
  15. Cpt Chattahah
    Meh. I love my TBT-7M, but, that's the last Trench Bucket I'll ever Master. There is no reason NOT to run a SHD over this...
  16. Falconium
    As always. PGI/IGP may not know how to make a good game, but they sure can put together a flashy, in-your-face video. Their graphics are pretty much always top-notch. So . . . maybe they should hand over the MWO game to some other producer/developer, and put their efforts into making a good 'MechWarrior film? Something that we can actually get excited about?!
  17. Jacob Ling
    Jacob Ling Benefactor
    220
    The videos are actually done by a player that was hired by PGI
    Go figure that their own team couldn't handle it.
  18. enileph
    My feel on this. Yes this is like a smaller 2D2 without the Ballistics. IT generally have the same speed with a slightly smaller engine, but it does have a smaller profile, which can be useful.
    I notice that if you use SRM4 build then the arm mounted tubes are more useful.
    Yes, on average I would still go for a 2D2. although this one can do 4x SRM6.
  19. Regina Redshift
    1,293
    It's The Wolf of War Street.
