EBJ-P 'Event Horizon' (3x cUAC5, 3x cERSL, TC1)
4.5/5,
4 ratings
Thread in 'Ebon Jaguar Omni Builds' started by KarbonKopy, Jun 16, 2015.
  1. KarbonKopy
    KarbonKopy New Member
    Always loved my my Ilya could do, and the Ebon Jaguar seems to fit this role quite well on the clan side. Geared to be able slam UAC rounds into an enemy 'mech while using it's small lasers to finish off the wounded utilizing it's level one targeting computer. I've been playing it similar to my Ilya as a support brawler.
    *Updated 7-3-15 by shifting the armor around a bit.
    First match in the build:
    Another great match:
  2. Gianky
    Gianky New Member
    KarbonKopy, delete the [smurfy] tags from and add an "s" to the http in your link, this way we'll be able to see it in here and to click on it to open it in Smurfy's. Thanks!
    KarbonKopy likes this.
  3. KarbonKopy
    Thanks Gianky! It seems I left the lower case 'c' out of my weapons load out in the title of the thread if an admin could modify that for me. Thanks!
  4. Gianky
    Gianky New Member
    You're welcome! :)
  5. Axex
    Axex Star Lord
    46
    Here's my variant:
    3x C-UAC5 + 6x C-ER-SML-L
  6. KarbonKopy
    How's it working out for you Axex? Heat an issue?
  7. Axex
    Axex Star Lord
    46
    Yes, it is.
    It was one of my experimental setups for the Prime.
    Changed it already for something completely new.
    But that doesn't fit in this built topic.
    Maybe in one of the others.
    Or I need to make one of my own.
  8. cs_kami
    cs_kami Benefactor
    434
    I use a similar build, but with one MPlaser over SPlasers and more ammo.
  9. Aylek
    Triple cUAC5 + triple cERSLas is one of my favourite builds on the EBJs so far.
  10. NLR
    NLR Active Member
    85
    i dropped the TC1 and maxed out my armor
  11. dranozir
    Good build with 6 ERSL
    When you are near to overheat fire with only UAC5
    Axex likes this.
  12. Aylek
    I forgot to rate this one after extensivly playing this build in both PUG and Faction Play. It's a great 'dakka mech' delivering strong DPS and nice suppression fire.
  13. anonymized1
    I play this, the OP version, it's a good build and fits right into my play style.
  14. Shock
    876
    357
    At first I tried 3 UAC5s with 2 ERMLs, thinking the range matched up better but it was lacking firepower when things got in close. Now I run it with 4 ERSLs and it's much better. This is a solid build
