Recommended : Quick Play - Fun. Pros: - You can lose a side, and still has firepower enough. - Jump Jets. - Massive Firepower. Cons: - Slow for the poke role. - Is a fact you will die killing a enemy and/or yourself .. - Easy Target to brawlers. How to play: It simply, you gonna harassing the hell out of enemy, in order to work this build , you gonna spread your fire groups in two sides, like in example: 1 - 1x cLPL + 1x cERLL + 3x cERML + 1x cMPL (Left weapons ); 2 - 1x cLPL + 1x cERLL + 3x cERML + 1x cMPL (Right weapons); 3 - 3x cMPL (as Back up / Torso & Head weapons); Use wisely, you first shoot with all weapons group 1, wait 1 second and fire group 2, it will make your heat goes ( 91% -99%) in frozen maps, after you do your max damage try to get cover or torso twist, you have 26 HDS ,so take like (20 or more seconds) for a new salvo. Get range advantage , you have a good poke for medium distance like 400-600, you can brawling a little but is not advice to enter in full HERO mode, cause you need time for refresh your shoots. and the most important thing, have fun. if you gonna die, just hit O and alpha-strike someone, you will die, but at least can take one more with you. Alternative Version: Tested in Game: Spoiler
How about this alternative: A little bit easier to handle heat wise, and not too much of a drop in damage capability. But having said that, there is some floating tonnage so it might be worth using the Prime arms and drop the jump jets to replace with a bigger targeting computer or moar DHS.
