DWF "Specialized" (3x cLBX10, 6x cERML, cAP, TC2)
Thread in 'Dire Wolf Omni Builds' started by Bmmagical, Sep 7, 2014.
  1. Bmmagical
    Bmmagical New Member
    I was always a fan of the 3x LB-10X AC build on the Ilya, so I found a reincarnation of it that works perfectly on the DWF.
    Clan active probe is only for target info gathering speed which is vital.
    I run UAV, CS9, Target Info Gathering, Seismic Sensor, and ERMlas Range.
    I run the Prime right torso for 10% better torso twist speed which helps smooth off this brawler build quite nicely.
    Fun fact, LB-10X Projectile speed is 1100 whereas U-AC/10 is a meager 950.
  2. Sentinel069
    Sentinel069 New Member
    Created an account just to reply to this. I am a super novice player, and this was the build I broke 1k damage in. I have a ton of fun every time I play it. Thank you for posting.
  3. Aza1979
    Aza1979 New Member
    I like the build, but I am a bad gunner, I need more ammo to inflict damage ;). I use it with 5 ML and TC1 instead of cAP + TC2 for ammo reason. As TCs increase not only target info gathering but also crit chances and projectile speed (both very useful in an LBX build, imho) I might swap 1t ammo to get a TC2. I am sure 1 or 2 tons of ammo can be swapped for additional DHS and/or cAP as well in my version for versatile pilots.
