DWF-P "Run, you fools!" (4x cUAC20)
Thread in 'Dire Wolf Omni Builds' started by ArsenicForHealth, Jun 18, 2014.
  1. ArsenicForHealth
    ArsenicForHealth Junior Member
    49
    Because it must be done.
  2. BindMind
    BindMind Advanced Member
    322
    Have you actually tried it? You'll only be able to shoot 8.75 times.
  3. Solahma
    B33f tried this... you will overheat instantly.
  4. RA2lover
    RA2lover Active Member
    88
    chanfire, you fools!
  5. Redshirt enraged
    Redshirt enraged New Member
    Hmm...if you hook up an ammotender,this thing maybe will work. :D
  6. Regina Redshift
    1,293
    I guess you'd need 12 shots to make it "viable."
  7. enileph
    Not nearly enough ammo for this to be functional.
    Tried it, does not work in combat.
    Maybe if you can get your friend to pilot an urbanmech moving behind you holding all your ammo.
  8. Falconium
    Let's make this thing viable . . . MOAR AMMOOO!!!
    10 tons, enough to actually make it worth while. Obviously low on armor, but so long as you force them to you, they should die so fast, it won't matter! :p :rofl:
  9. Durandal
    I almost want to try it. Imagine this little bastard camping the tunnel in Forest Colony...
  10. Auriga
    Auriga MechSpecs Addict
    599
    Just testing. The 2 UAC20s that u cant fire without insta-overheat worth all this equipt in weight:
    EDIT: [member=3228]Solahma[/member] comment (the post below) made me think it twice. I think this should be runneable. 4 cERMLas are a nice backup and the ammo is 9 tons, so 3 tons/gun, enough to involve in long fights:
  11. Solahma
    Tried 4 with a macro that will cycle through them all in a chain fire, then double tap them before the cooldown finishes. Works alright. It's still very hot, but at least you can put out Max DPS. The ammo runs dry very fast as well.
