100 Point Alpha you can "almost" fire the shutdown is very short assuming you have this mech with double basics, which I highly recommend having if you want to try it. However I tend to have left click for left arm LPLs and right click for right arm LPLs then two other groups one for torso mounted MPLs and the other for arm mounted MPLs. And a third to fire all the MPLs which I combine with the LPLs in the case I do alpha strike. Don't use the LPLs unless enemies out of mpl optimal range or if you need that extra damage to take a kill or component. Also can be ran on the DWF-W with 1 extra heatsink I believe.
