New DWF-S side torso omnipods are high mounted and level with the cockpit. That means that just about every weapon on this mech will hit the target as long as you can see it! The new DWF-S head also makes for a great cERLL slot. I optimized this build so Ghost Heat isn't as much of a concern. On a heat neutral map, you should be able to alpha once and barely miss overheating. Hotter maps will certainly overheat though. You can avoid this by chainfiring the large lasers or firing them in groups of two. Not the right loadout, but you get an idea of the hardpoint placement
