Absolutely USELESS build but goodness kind of shows the potential. I actually used this in a couple matches and insta-coring heavies just doesn't get old. I alpha'd a full health Atlas and took him to no armor and orange core instantly. I made this just for a giggle and thought oh hell, why not show it to you guys. I would never run this except when you have had a bad day and its fun to just vent. Someone said Dires can't brawl...try it with this thing because big torso or not nothing lives long enough to really hurt you. Surprisingly enough the alpha won't overheat you and I have mine grouped 4 ways. Button 1 - Alpha everything (how the mechs supposed to be used after all its the most fun) 85-90% heat on a hot map Button 2 - Chain fire everything (amazing spammability considering. Can chain fire everything for a good while, okay, 6 seconds but thats still 160dmg ) if you press the fire button as fast as you can for a minialpha it only takes you to about 65% heat. Button 3 - Alpha the LAAAZORs (good for long range when you don't want to waste your ammo) good for 2 alphas before cooling down. Only...ONLY 75 alpha at 450 meters though. Button 4 - Chain fire the LAAAZORs Could I drop a ML or 3 for 3 MPLs? Sure I could...but that would just be...well, Nuts.
If the mixed ghostheat thing is still glitched then: http://mwo.smurfy-net.de/mechlab#i=173&l=4476bf3b8ce9fb59725b36cc4c3b1b1c5129f7d1
