This build is something I came up with based on the same concept as the Alpha Dog: melting through as much armor as possible. The Alpha Dog is designed to punch straight through your enemy's face, and does this very well, but it's only able to fire 2 volleys before heat becomes a major issue and thus doesn't do well in a skirmish type setting. That is where this build is designed to shine. By chain firing your large lasers you can have a constant 20 or so DPS at a very long distance, which will usually peel off a lot of armor and allow your allies to easily drop the opposing 'mechs. If you find yourself in a close quarters situation the MGs provide good dps and no heat, which can easily tear apart your enemy after you've stripped their armor. The most important thing to remember about this build is to chain fire and to discipline your trigger finger so you don't overheat. Basically, "Patience you must have, my young padawan".
