Dragon Slayer "Budget Slayer *Kind Of*" (1xPPC, 2xERLL, 2xAC5, 1xJJ, XL330)
Thread in 'Dragon Slayer' started by Pwnanza31, Nov 27, 2013.
  1. Pwnanza31
    Pwnanza31 New Member
    My little take on the Dragon slayer, this build is working pretty well for me. Just need some heat discipline.
    I like to run my AC/5's on chain fire. What yall think?
    Also I did want to try a build with two srm 6 packs and just trim the larges down to mediums but with srm's behaving the way the are is it worth it?
  2. Crazykeats
    Crazykeats New Member
    Served along side this. Its like playing a run and gun shooter along side it. So much ownage!
  3. Pwnanza31
    Just an example [​IMG]
  4. Regina Redshift
    1,293
    Would it make sense to shave ~1/2 a ton of armor off of each leg in order to mount an additional JJ? The fewer JJs I have, the harder it is for me to dodge/soak incoming fire.
  5. knightwolf47
    knightwolf47 Active Member
    57
    Shouldn't be a problem. I run with about 480 or so armor on the Slayer & haven't had too many major issues with weak spots. If you have trouble with heat, check out Vergere's "Autocannon 5" variant. It's basically this variant with 3 large lasers instead of 2 LL and a PPC. I run it with 3 jets and it works pretty well. Debating sacrificing another HS and some armor for a Beagle.
