This build takes advantage of the dragon slayers maneuverability, and allows for good long range damage and a little extra kick from the mediums if they get too close. It has been working very well for me. I previously had a LRM10, but i discovered that by using 2 LRM5s i saved an extra ton that I could use for an AMS. There is no negative for using 2 LRM5s over an LRM10 either. Weapon Groups: 1: ER PPC 2: Gauss 3: Medium Lasers 4: LRM5s
I wouldn't call it a bump, I would call it an edit. That said, you could reduce the engine in order to run max LRM tubes.
