Been meaning to pick up the 'Phracts for a while now and was intent on using a 2xUAC5 build that had been posted on the MWO forums. Turns out I was no good with that build and I put this thing together instead. The idea behind using the dual LBX10 is that it, in a way, mitagates the importance the potential weapons spread from having one of the ballistic hardpoints in the torso and the other in the arm. Sure, I could also of used arm lock instead but I hate how clunky-feeling it makes torso twisting. Weapon groups: 1: 2x MLas 2: 2xLBX10 3: 1x PPC The PPC lets you deal some damage as you close-in on your target but it can also be swapped for a LPLas if you want to maximise brawling power. I haven't had a chance to test this out yet but I expect it to work pretty well even though it means you absolutely have to get into brawling range if you want to deal any meaningful damage.
