CTF-3D The Nasty Cat (2x LBX10, 4x MLas, XL320) + V2
2/5,
1 rating
Thread in 'CTF-3D' started by UntamedZer0, Mar 10, 2013.
  1. Omniknight
    Omniknight New Member
    Cool, thanks. I like the double LB 10-Xs, but swapping one out for an AC10 is an interesting idea. Regarding AMS, I find I don't miss it all that much if I play properly and don't get caught out. If I do get targeted, with 86.6 top speed I can usually avoid most LRMs by getting behind cover in time.
  2. Thiak
    Thiak Well-Known Member
    244
    nice build but its missing an ams for me, there you go (and added another ton of LB-X ammo as you can run out pretty quickly with only 4 tons):
  3. mmstahlman
    mmstahlman Active Member
    84
    I run a very similar loadout on my CTF-IM. Started with three AC/10's (which was amazing fun) but found that I could get similar affect with two AC/10+MLs and settled on this:
    I am going to have to give the flying LBX/10's a shot. This looks fun!
    EDIT: I stay back until I had a chance to use some of the extra AC/10 Ammo... 90 is a lot, but if you can hit with most shots it's a chance at 900 damage not counting the MLs... Play is similar to AC/20 BJ-1 but with faster recycle on the AC and 450 meter effective range.
    Also wanted to mention, I have had my dual AC/10's strip BOTH the LBX10's from a (mostly) fresh Atlas in two volleys. I was laughing so hard I cried...
  4. swampwalker
    swampwalker New Member
    I tweaked the original to fit my tendency to forget heat a little too often and shoot a lot. Dropped the engine down to a 315xl and one jump jet, still hits 80kph and can dance around and over a lot of mechs. This build is my go to when I just want to have fun and rip stuff apart.
  5. boods
    boods Active Member
    85
    I tweaked it a bit, but I love the double LBX.
  6. Evvo
    Evvo MechSpecs Addict
    537
    Updated mechlab: https://mwo.nav-alpha.com/mechlab?b=ad58c8e6_CTF-3D
    Enjoyed running this. Gets decent speed and good ammo, and myself packed it with some jj's that gets you places, great for flanks and positioning. MLs helps open up enemy for the LBXs. Advise to check out the mobility tree. Many options for personal preference.
    Highest damage played: 970
  7. Evvo
    537
    Lacking in firepower, SBG would be better
