CTF-3D Pellets Aplenty (2x LBX10, 1x ERLLas, 2x MLas, XL300)
Thread in 'CTF-3D' started by Skyer Stralende, Sep 8, 2013.
  1. Skyer Stralende
    Skyer Stralende Junior Member
    Inspired by Thunder Mop, this build has been fun and effective for me from the start.
    -The ERLLas in the left torso helps annoy enemies at range and rack up assists, so you can always be doing damage if you see a target.
    -The ML's in the arms are great for lights and things up close.
    -And of course the LB10-X's are tons of fun (27 with ammo)! I try to shoot them only when most of the pellets will hit an enemy to keep the ammo on tabs (or I shoot when I want an assist). But... what I enjoy most is getting within 100 meters of some poor soul and firing everything into his cockpit. The combination of lasers and spread damage from the LB10-X's can be quite effective in this manner!
    The single jumpjet helps you move around terrain and brawl, and you've fairly decent heat efficiency with the 300XL and 14DHS. Just mind your torso-twisting damage absorption, and you can do pretty well. I suppose you can probably remove some things (Perhaps 2 DHS, since it's a relatively cool build) to make room for AMS, but I've never been a huge fan of losing the tonnage even if I should be...
    AMS Variant:
    Pros:
    -Useful at any range
    -Great brawling
    -Relatively maneuverable
    -Can sweep lights
    -Decent heat efficiency
    Cons:
    -XL Engine
    -Watch the ammo
    -LB10-X ear candy might distract you from the carnage at hand
    Overall, I've been having a lot of fun with this build since I started running it a few days ago! Now, perhaps, you can enjoy it too. ^_^
