CTF-2X Grimm Hunter (1x AC20, 3x MLas, 2x SRM4, AMS, STD295)
2/5,
1 rating
Thread in 'CTF-2X' started by Michael, Jul 6, 2013.
  1. BRUTAL FURY
    BRUTAL FURY Active Member
    Hello friends! this build is really devastating! See the images below that made no assistance, but killed everything in that shot!! 7 kills total (thief kills? too, yeah!).
    http://i44.tinypic.com/2v0c2lv.jpg[/img]
    I used a setting almost identical to the "Red M3nace", however, with different armor points and different placement of the ammunition (was perfect). View full loadout.
    Until next time!
  2. Michael
    You can't use sky drive images. Anything with an https in it won't get parsed properly by the image reader.
    I've gone to the Skydrive and snagged the images and uploaded them to Tiny Pic.
  3. Jay Z
    Jay Z Well-Known Member
    102
    This is probably what I would run. (I'm thinking about getting the Cataphracts)
  4. Aylek
    Skip the AMS. You definitely want more cooling in that monster.
  5. Jay Z
    102
    Howzat? Is it worth stripping a ton of armour off the limbs for that last heatsink?
  6. Aylek
    Considering the punch of your secondary weapons you probably only need 4 tons of AC ammo. Problem solved.
  7. Evvo
    Evvo MechSpecs Addict
    507
    Build: https://mwo.nav-alpha.com/mechlab?b=8bcc4a1f_CTF-2X
    Challenging hardpoints and setup, but a good brawler when you get the hang of it. Usually have to expose your whole mech, and pushing or peeking over hills is much better than around corners. My impression that because of this setup you need a supportive team to make use of its effectiveness
    Highest damage played: 910
  8. Evvo
    507
    SRMs is hard on this slow mover, and doesn't sync well
