CTF-1X Updated Classic (1x AC10, 1x PPC, 4x MLas, AMS, STD280)
Thread in 'CTF-1X' started by TheWatchman, Aug 20, 2013.
  1. TheWatchman
    TheWatchman Dispossessed
    An update on the classic CTF-1X load-out. With both the DHS and Endo Steel upgrades installed, the build benefits from significantly better heat efficiency, as well as an extra ton of armour and more ammunition for the AC10. Sticking to standard model Autocannons and PPCs helps keep the cost down, though with DHS and Endo Steel installed, its probably not that much of a saving.
  2. The Verge
    I would run a larger engine over that many DHS, but a good upgrade none the less.
  3. Blagg Zear
    The Stock.Weapon.Loadout is not bad. I'd tweak it a little bit different, closer to the original stock:
    or XL340 (Max):
  4. NamesAreStupid
    NamesAreStupid Active Member
    how do you group it? arm lock?
  5. TheWatchman
    Switching the PPC position makes weapon grouping easier:
    Possible weapon groups:
    Group 1: AC10 + PPC
    Group 2: MLas
    Group 3: Alpha Strike
  6. Excalibaard
    5,064
    1,108
    This would be even better weapon grouping, though you will lose a lot of fire power by losing right side.
    Still, this pseudo AC20 makes me very warm from within, Very anxious to try this out!
    Also possible with STD300 though due to heat reasons I drop the 4th ML in the torso (or arm, your choice) instead of yet another heat sink.
    EDIT: I just got 590 damage the first time running the STD300 variant of this build.
    The increased range over AC20 makes this build a BLAST! Uploading video!
