CPLT-K2 Pew-Pew-Pew (2x LPLas, 2x LLas, AMS, XL300)
Thread in 'CPLT-K2' started by epikt, Apr 8, 2013.
  1. epikt
    A variation on the classic 4LL K2.
    Awesome mech, very mobile and with great fire-power at close/mid range.
    At first I trade LL for LPL to maximize hits on fast moving targets protected by lagshield. Not sure if it still really worth it since the net code improvements, but I like the feeling of pulse lasers and I kept using this build.
    It's build in order to mount as many DHS as possible, but it still runs pretty hot and requires good heat management.
    I personally mount the pulses on the arms for more mobility.
    PS: I also tried a 4*LPL build, but I don't recommend it for two main reasons:
    - damn it's hot!
    - the higher range of standard LL gives you more versatility.
  2. Blagg Zear
    Hi there, i give u full points for this very good build. I always wanted to mount 4 LL or 2LL+2LPL in my CPLT-C1 but that would waste the missile pods. So the K2 is perfect for this weapon setup. What i find amazing is the good Armor and Speed this Cat has. Plus u even have AMS. Well done!
    Blagg Zear
  3. The Verge
    I would call this build good. You can't snipe with it, only to about 600m. But I would be happy to see it in a brawl. good build OP.
    "Heat really stands out" -All Mechs Magazine
  4. Michael
    Got hit with the nerf due to LLas, LPLas and ERLLas all getting heat grouped.
  5. Cpt Chattahah
    Only requires a .5 second delay when firing, correct? I have not experimented to see if that includes fire duration or if it is from the beginning of the time the weapon is fired...
  6. ArkNemesis
    ArkNemesis Well-Known Member
    107
    I use this build :
    http://mwo.smurfy-net.de/mechlab#i=19&l=1e358ab966e22bf79d71edc47d6819b4b08aa31d
    ER-Las in arms allow me to snipe, and pulse and MG in torso have a good convergence. The CAT has a real good twisting ability, thus it is not a real disavantage to have the LPLas in torso.
    As long as you don't fire both type of LLas simultenaously, heat is manageable.
    I wonder if I should remove the MG for AMS.
