Boar's Head "Tusk Soldier" (1x AC20, 1x SRM6+A, 2x LLas, 4x MLas, STD300)
Thread in 'Boar's Head' started by Darkblood, Oct 1, 2013.
  1. Darkblood
    Darkblood Active Member
    50
    This is me looking for a solid brawler build on this one, but somewhat balanced to be capable of dealing damage at mid ranges (I don´t like the idea of depending on bringing such a slow thing on MPL ranges to be effective).
    Comments?
  2. Tuku
    Tuku Well-Known Member
    217
    Ya know I built one identical to this but I did not add artemis because it is so hot that you wont use the SRM6 unless you are right in someones face anyway .
  3. Lan
    Lan Mech Wrangler
    1,570
    Stick the AMS ammo in the head and the AC20 ton in the RT. Drop the CASE, it's only 7 shots. You think you will get torso crit before you fire 7 times?
    Other then that, my main concern is the 300 which is bare minimum for a Atlas. Not a bad build overall, if I get a BH I will do something similar with a bigger engine tho.
    You know you are dropping the Endo frame it comes with I hope? It's not a bad idea necessarily, on many builds it's required to reach cooling levels with DHS.
  4. imrichking
    imrichking New Member
    My build is similar to yours, although I dropped the SRM launcher and some armor, in exchange for a bigger engine and a couple of extra heat sinks. It runs cool enough, and what I've lost on the Alpha strike, I've gained in sustainability.
