Perfect for ranged combat, but also very well equipped to fight in close quarters, this build provides a good mix of meta and meat-grinder that I think most any pilot would appreciate. It's perfect niche is probably between 250 and 400 meters, where the LRMs, PPCs, and the LB10X all function with nearly optimal efficiency. Within 90 meters, it obviously lacks a bit on firepower, but a good pilot knows how to remedy this --- by killing enemies before they get that close! The one downside to this build is speed. I don't like running anything slower than a 325 engine in a Banshee, but when it becomes necessary to do so in order to maximize the power and efficiency of a build, I'l do it. This one compromises a bit with a STD310 (which I and most other Stalker pilots do happen to own). For the ultimate meta fans among us, drop a DHS to change the LB10X to an AC10, for more punching power. And if you're really insane, and you happened to buy La Malinche, check out the speedy version of this build!
