I was looking for a High Alphastrike Build by using every single HP, this damn Killing Machine offers me. But also a build which gives me Versatility for any Situation. Now this here! 70+ Alpha/19 Maximum DPS and you won't even overheat after your first Alpha! That means you can do 2x 70 before you shut down! You can put the Weapons in different Groups to use them tactically for every situation. In my testrun i just fired the LLas (linked) at ranged targets. For mid range Brawling i add the LBX, for close range i add the SRM6. The Attack gets more disruptive & "critical" the closer you are. And for a deadly Finisher or to quickly dismantle relevant components at sub270m range, simply aim at Sidetorsos and Alphastrike. If Enemies turn their back to you, they will quickly realize how fatal this mistake is. Heatmanagement is quite ok. Just save the Hexa MLas Beam really for the end of a 1v1 Brawl or if you see a reddish component. Without the Hexa MLas Beam you still have 40+ Alphadamage, a 55% Heat Efficiency and a max Sustained DPS of 6.30! So don`t worry if you don`t use the MLas early. In my first testrun i engaged four Enemy Assaults directly - a Laserboat-Stalker, a PPC-Awesome, an Atlas (ok Gauss and LRMs, was easy) and finally an Enemy Banshee. I could take down three of them, while one was stealkilled. Weapon Groups. 1. LLas (linked) 2. MLas (linked) 3. LBX 4. SRM4 testrun: Blagg
