BNC-3M "Pop . . . Burn . . . Zap!" (2x PPC, 2x LLas, 3x SPLas, 21x DHS, STD325)
Thread in 'BNC-3M' started by Falconium, Mar 20, 2014.
  1. Falconium
    An energy build designed to provide a little bit of everything, while still maintaining a relatively good heat efficiency. You could obviously swap the SPLasers out for standard MLasers, but that would increase your overall heat output; the SPLasers provide nearly the same DPS as MLasers, but with less heat.
    Still, this thing is gonna run hot, so you'll want to be extra careful with those trigger-fingers. :p
