BNC-3E "WRATH OF GOD" (1x LBX10, 2x Llas, 2x MLas, 3x AC2, XL340)
Thread in 'BNC-3E' started by Tr0unce, Apr 8, 2014.
  1. Solahma
    The truth comes out! Trouncy just wants to play with Blagg a bit and get friendly :p
  2. Excalibaard
    5,285
    Leaving out parts of people's points takes them completely out of context. You see each point seperately while the mech is a whole. Example:
    You say the hardpoints are high, which is true for some of them, yet some are clearly on the bottom-mid section of the side torso as can be seen from the mech's model. This means that you cannot produce maximum DPS with only exposing the high hard points, while you can do that with a Jager (assuming the jager does not use energy hardpoints, as per your 5AC2 build).
    However high the other points may feel to you, exposing the bottom half of your torso is significantly more than you need to do in a jager. That means you simply have to walk up further, give more area for the enemy to target, and walk back down further. That, combined with slower speed makes you a vulnerable target. You have armor to back it up, but while a jager might pop back before people's reaction time kicks in and subsequently for their shots to reach your position, the banshee will have to use much more of its armor against the incoming fire.
    Thus, either you 'play like a jager' or you get maximum DPS, not both at the same time.
    A hypothetical situation with arbitrary numbers: Assuming a 1 second reaction + shooting time (which is reasonable for unexpected things), the jager going back and forth in 1.5 seconds over banshee's 2.5, the banshee will take triple the damage a jager would, and the armor is not triple as high. ergo, the jager playstyle is much less effective on the banshee, unless the actual numbers are a better ratio than the armor ratio between jagers and banshees (around 1:1.5)
    I did not claim firing at 350m is an absurd viewpoint, I said that a lot of pellets start missing at that range already. I claimed firing the LBX at long ranges was, which was implied by mentioning the 1620 maximum damage range, which I used as an example. Interpret it as 'firing an LBX at 1620m is a complete waste of ammo', which also counts for 1000m and ranges where LLs might still be doing reasonable damage.
    EDIT: sorry for keeping the cold mood. Happy fun times will come after exams.
  3. Tr0unce
    Tr0unce Active Member
    97
    Your detective skills are spot on solahma. :rolleyes:
  4. Blagg Zear
    ow damn, now the reason is out for the Aggressive Tension here! It's all MY Fault. I should play with you all more often, or maybe in future more people won`t love me... hehe. Fortunately i experience soo much love in almost every round i play in MWO with people telling me, that they like Mechspecs.com because of people like crazy me. Besides, 500 Posts a day would be challenging even for ME! Let me see... daaamn, only 10.221 per day. :( Sorry for being not so talkative. I have to work on myself. :rofl:
    p.s. whenever you see me online, try to pm me for a game. Whenever i am not busy with experimenting with crazy builds in the Mechlab and testing them out solo, i usually play with you. Aylek & some other dudes in my friendslist can tell you better. :rolleyes:
  5. Solahma
    ^_^
    You may have the Wrath of God, but you haven't suffered the WRATH OF SOLAHMA!
  6. Excalibaard
    5,285
  7. Michael
    So ummmmm... calm down everyone? Otherwise this could happen to you!
  8. Blagg Zear
    I like the third Suggestion in the OP. 3x AC2 + UAC5 can be grouped on one Button, while the Lasers in a second Group. Userfriendly and even more effective.
    I will try a Mod of it tonight since i have the XL350:
    And also this one:
    Heatefficiency looks horrible, but i use the Lasers as Finisher if needed.
    Will come back with some scoreboards. Let's see if I can brawl with it.
  9. Excalibaard
    5,285
    Just increase armor instead of getting an XL355. It'd only be worth it for the number of 66.6 kph
  10. Blagg Zear
    First Round:
    Could carry the game with my Dakkas.. and the Match ended after ~5 Min. Rush Attack. Btw we had a Disco!
    Capture is in my Video Thread.. here :rolleyes:
