BLR-1S The Beast (4x SRM6+A, 2x LLas, 2x MLas, AMS, STD300)
Thread in 'BLR-1S' started by IanSane, Oct 15, 2013.
  1. The Verge
    What's the trouble? let's fix it together!
  2. Goregrimm
    Goregrimm New Member
    I was having trouble with the slow speed. I am used to much faster mechs but I am reworking my S back into this configuration for another go. Thanks for the build and the offer. I will report back after a couple runs.
  3. The Verge
    The Key for you might just be AMS. Or Torso Twisting. easy or hard, take your pick.
  4. Solahma
    "Enter back-door code: THE BEAST" :rofl:
  5. Thiak
    Thiak Well-Known Member
    244
    you can run it with an XL 365 if you want speed, like this:
    edit:
    this build is so much fun if it just wouldnt run so extremly hot so fast
  6. Kryten 2X4B
    Kryten 2X4B Active Member
    Cheap version, with stock engine, no ghosts...
    Cool
    Ams
  7. Lavandel
    Lavandel New Member
    Can't build this 'Mech.
    Lack one critical-slot.
    Even if I strip the mech in smurfy's and rebuild it from scratch, I still lack 1 critical.
    Anything they've done to the chassis lately preventing this build?
  8. Auriga
    Auriga MechSpecs Addict
    599
    @Lavandel Probably the upgrade to ArtemisIV.
  9. Lavandel
    Lavandel New Member
    So the ArtemisIV takes up one extra criticalslot nowadays?
  10. The Verge
    As it has been since the closing of beta.
  11. Lavandel
    Lavandel New Member
    The original build of this was created October 2013.
    Well after release.
  12. The Verge
    Then you have found a bug in smurfy. I recommend emailing him.
  13. Lavandel
    Lavandel New Member
    I actually found out when I tried to build it in-game.
    Didn't work so I did some experimenting in Smurfy's and came to the same conclusion.
    Too bad.
    What I've got is this instead:
    Annoying that I lack half a ton.
  14. Excalibaard
    5,285
    I think all battlemasters had at some point one hand actuator slot added. That is probably that one slot you need.
  15. Cpt Chattahah
    Just tried this line of thinking out this weekend for a CW drop.
    I used a massive XL (XL360) for over 75kph after tweak, 600 rounds of SRM ammo in 4x SRM6+A and 3x LLas.
    I'd use the LLas to poke from range (hooray for the Ghost Heat nerf) then open up with ONLY the SRM's at close range, chain-firing the LLas on open components.
    Only did one drop in her, but, racked up 5 kills and 900 damage. Not bad for an XL Assault! :thumbsup:
