This is just an upgraded Battlemaster... not a boat or specialist. It is actually best suited for grinding xp & c-bills with the LRM, PPC, & AC10 giving you range to run around hitting a lot of people to get Kill Assists. The speed is only slightly better but the armor is maxed and the heat efficiency is very good (45% for the MLs, the others are higher) since it isn't designed to Alpha but use each system separately as needed.
Same concept but dropped Artemis, 1T of LRM ammo, & 1T of armor off the legs to put a Gauss Rifle in the place of the AC10...
