So I once read somewhere that it was cringe-worthy to build an assault like a medium. To be fast with less firepower is a bad thing. So here is my enlightened Battlemaster. Slow. Near-max armor. Near-max weapons. Zero vacancy. Zombie-mode, nominal. Take no prisoners, because they will walk faster than you anyway.
That said, no one has posted a STD250 version of the 1V1. Swapping out the AC2s and a couple heatsinks for AC5s results in a fairly cool running version of the build without losing any of the firepower. This thing is slower than mollases, and probably turns about as well as a train.
The only notable differences are that the 2xAC5 are now 2xAC2, a downgrade in engine size and filling it up with heatsinks. This is not a new build, it's min/maxing of the other already established build. Of course it's a pretty gray area and very subjective, yet the entire energy points loadout is the same, the ballistic weapons are very similar (both long range sustained damage hitters) and most importantly, they basically have the same role.
