This is my initial build that I went away from and then eventually returned to. Works very well. What I do is to group the Mlas on mouse 1, and the PPC and Gauss together on mouse 2. That way I can fire only the PPC by tapping and both by holding the button and release it to let go of the gauss round. I then bind the Gauss alone to mouse 3 to fire it when heat is high. Takes some practice but works fine now. Duke Nedo EDIT: If you don't like the Gauss thingy, you can switch out for 2x AC5. Directly applied alpha but @ lower damage and more heat. Example:
I like it. Good all around load out. I just tried this same one with ERLas instead of the PPC. It was great.
