BLR-1G Brawler (1x ERPPC, 1x LRM10, 1x LBX10, 4x MPLas, 1x MG, AMS, STD280)
Thread in 'BLR-1G' started by Notactjack, Oct 16, 2013.
  1. Notactjack
    Notactjack New Member
    I want to try this out so I can pub it up.
    It's got max Armor and 14 DHS.
  2. Serious Table
    102
    That 280 means you're going to be really very slow, which feels like you're not taking advantage of one of the biggest things the Battlemaster has going for it: it's speed.
    I made a few changes to try and facilitate better brawling. Dropped the MGun and MGun ammo, then swapped the LRM 10 out for an SRM 6, changed one ton of ammo to LB-X, and upped the engine. Here's what I've got:
    Now all your weapons are able to be brought to bear when you get into brawling range, and lets you be a bit more liberal with your LB-X shots.
    Another suggestion might be changing the ER PPC to just a standard PPC to up your cooling efficiency, and lets you focus on the pulse lasers when things get under 90 meters.
