Suppress with the Ballistics by simply holding down the Firebutton. Save the Pentalasers for accurate Hits on weak components. You have enough Ammo to break 1K. The Downside - running an XL Engine with so much Ammo means, you must avoid heavy damage. But i don't have to tell you this. If you feel you need more survivability, you can run a common STD300 instead at cost of Mobility. It's your choice. Alternate "STD" Version: Alternate "Insane Ammo" Version: Testruns: Blagg
Battle masters are next on the wish list for mechs after the phracts' are done.... I cannot wait to try the hail of dakka
