BJ-1 Hollander (1x Gauss, XL235)
Thread in 'BJ-1' started by knightsljx, Jan 26, 2014.
  1. knightsljx
    knightsljx Well-Known Member
    129
  2. Blagg Zear
    did you post this build because you find it practicable viable or just for the sake of posting something like the Hollander?
    1. No Endosteel enabled -> Reason?
    2. No Ferro enabled -> Reason?
    If you enable ES & FF you could have some Backuplasers for the case someone shoots off your right arm
  3. Aylek
    Truth you speak. :D
    Any reason to post a suboptimal build in a forum aiming for min/maxing?
  4. Cpt Chattahah
    I just popped it into Smurfy's and came up with exactly the same idea as Aylek. Dual MLas on the arms give more close-range snap-shot pinpoint and mid-range support.
    Other opt. would be to keep Std Heatsinks, saving yourself 1.5m C-Bills and use FF and Endo which gives you an extra ton for ammo and a heat efficiency of 43% (50% once elited)
    Chatt.
  5. tfun90
    Seems like you could STD this build without losing too much.
  6. knightsljx
    129
    I WAS WRONG. THIS IS THE TRUE HOLLANDER!!!!
    Hollander has Ferro
    Hollander has Endo
    Hollander no JJs
    Hollander shoots 20 times
    Hollander runs at 80+kph
    Hollander is NOT competitively viable
  7. Excalibaard
    5,278
    Hollander is a 35 ton light.
    BZK-G1 variant also has 2 ML
    This forum is still for min/maxing, not for thinking up sub-optimal variants on mechs that are not in the game, unless you make a thread specifically for that in the general section ;)
