This build is pretty simple and uses all the B Omnipods to get the 15% cooldown bonus on the AC-20 which really helps synch your weapons. It is a short range murder machine, left click all the weapons to fire in a single alpha strike then twist away, rinse and repeat and your foes will fall shortly. It runs pretty cool so you can keep the fight going. Killer around 300m, sucks at range. The ECM helps to get the drop on unsuspecting foes. Lead the charge!
