The new lurmageddon assault. https://mwo.nav-alpha.com/mechlab?b=a97773c0_BANE-3 https://mwo.nav-alpha.com/mechlab?b=d9c6fbaa_BANE-3 https://mwo.nav-alpha.com/mechlab?b=c3a94e24_BANE-3 <10 ghostheat https://mwo.nav-alpha.com/mechlab?b=9a98aaae_BANE-3 <10 ghostheat https://mwo.nav-alpha.com/mechlab?b=354c10bb_BANE-3 atms More dakka please. https://mwo.nav-alpha.com/mechlab?b=0a27d9dd_BANE-1 12(11)xUAC2 https://mwo.nav-alpha.com/mechlab?b=a54d5fc9_BANE-1 https://mwo.nav-alpha.com/mechlab?b=2ecc1fa2_BANE-1 2xUAC10, 4xUAC5, 8xLMG https://mwo.nav-alpha.com/mechlab?b=39741e93_BANE-1 Dakka and APG https://mwo.nav-alpha.com/mechlab?b=b9a418fa_BANE-1 Do Ballistic and Energy HSL stack? https://mwo.nav-alpha.com/mechlab?b=a955804d_BANE-4 https://mwo.nav-alpha.com/mechlab?b=f005044f_BANE-4 Hot surprise https://mwo.nav-alpha.com/mechlab?b=48f8510c_BANE-6 UAC2 ECM https://mwo.nav-alpha.com/mechlab?b=db1031f1_BANE-6 https://mwo.nav-alpha.com/mechlab?b=086cac8d_BANE-6 Shotgun https://mwo.nav-alpha.com/mechlab?b=1a37e8ea_BANE-1 6xUAC5, 2xUAC2 https://mwo.nav-alpha.com/mechlab?b=42bd9a21_BANE-2 ATM and Narc https://mwo.nav-alpha.com/mechlab?b=347609b4_BANE-3 https://mwo.nav-alpha.com/mechlab?b=5c05de58_BANE-3 2xUAC20 and PPPC brawler https://mwo.nav-alpha.com/mechlab?b=983a1c6b_BANE-7 2xUAC20 and ATM brawler https://mwo.nav-alpha.com/mechlab?b=98ebbe3d_BANE-4
BANE 2 got a Ballistic HSL. Quirks WEAPON VELOCITY+7.5% BALLISTIC HSL+1 BASE ARMOR (RT)+10 BASE ARMOR (LT)+7 BASE ARMOR (RA)+12 BASE ARMOR (LA)+12 3xHAG40 https://mwo.nav-alpha.com/mechlab?b=a70e0e4b_BANE-2 6xUAC10 https://mwo.nav-alpha.com/mechlab?b=d8c51d2c_BANE-2 3xUAC10, 3xLBX10 https://mwo.nav-alpha.com/mechlab?b=1a60635a_BANE-2 2xUAC20, 2xUAC10, 4xAPG https://mwo.nav-alpha.com/mechlab?b=e835bc4a_BANE-2 3.5x AC20 no ghost heat https://mwo.nav-alpha.com/mechlab?b=dd06ff4e_BANE-2 3xUAC10, 4xUAC5 https://mwo.nav-alpha.com/mechlab?b=e26b797e_BANE-2
2xHAG40s and 2xERLL, TC6 https://mwo.nav-alpha.com/mechlab?b=d58c4756_BANE-7 2xHAG40, 3xERLL, SHS https://mwo.nav-alpha.com/mechlab?b=2f9f2843_BANE-7 Can fire two salvos will skills. https://mwo.nav-alpha.com/mechlab?b=c45ebb7a_BANE-6
https://mwo.nav-alpha.com/mechlab?b=1c7839e4_BANE-1 LBX build with lots of ammo. Can be remade with AC5s and AC2s.
MechDB - BANE-2 Very hot, but devastating build at close range. MechDB - BANE-2 This is probably a lot better in almost every way, except initial burst. Spoiler easy win, fast mechs cleaned up good damage for a tough loss good game, all or almost all ammo fired
https://mwo.nav-alpha.com/mechlab?b=d9748074_BANE-3 A missile brawling Bane 3 build. The sweet spot is 60 - 350 meters limited by minimum range on ATMs and maximum range on SRMs with skills and quirks. Don't worry about getting a lock if you are inside 350 meters. The missile speeds are different, so consider that when aiming. Maybe fire SRMs, then adjust and launch the slower ATMs. Spoiler Was able to get a 1k game in a trial run.
