Hello there this is my second post for Atlas DDC and i have yet another weird build to share to everyone. It is my answer to BRUTAL FURY *Koolossus* Its has 17 DHS, i whooping 350STD engine for faster torso twist + reactions But compare to the *Koolossus* this one is more towards short range build. Its Alpha is not as high compare to the usual AC20+3xSRM6, but its has high DPS. i usual groups weapons like so: 1) Lb10x + ac5 2) 2xmlas 3) 3xsrm4 The LB10x and ac5 has short recycle time, so first thing i'll do is get as close to the enemy target. When thats done, just keep firing the lb10x+ac5 and srm4, which ever finish its recycle i'll fire it again. So the trend would be like a continuous dakka from those weapons. As for the mlas i normally fire them once in a while depending on heat. Talking about heat, this baby has high heat efficiency (1.45 in game) so you can keep the brawl+dakka going for quick sometime. And due to the low and compatible recycle time of the ballistic and missile you can really keep your target rocking~! It has its flaws, 1) If you cannot keep firing those weapons you won't be able to do decent damage 2) If you were to face to face toward a Clan mech with a lot of UAC,you'll be outgunned for sure. 3) If you meet a AC20+3xSRM6 DDC, you will lose normally unless you get lucky / or has better skills ITS not the best build, but please leave your comments, rate the build, let me know your opinions. Thank you!
I wouldn't 5 star this build if hadn't seen it in action. The initial hit is scary, and the different recycle rates for each weapon ensures there's always a weapon going off.
