AS7-K Medium Range Support (1x LRM20, 1x AC10, 2x LLas, 2x AMS, STD300)
Thread in 'AS7-K' started by Tuku, Mar 8, 2013.
  1. Tuku
    Tuku Well-Known Member
    217
    Ello my name is Bob and I will be assisting you in your long range killings today :)
    Bob was built out of my want to make the Atlas K useful and the only thing that I could come up with is Medium Range Support.
    Basically this mech is built to operate with a team within 300m of the enemy so that you can use all of your weapons...Im just curious as to what others say about this build now.
  2. Regina Redshift
    1,293
    I sort of hate to stack ammo into the legs of 'mechs with standard engines, at the same time, I'm not sure how I'd spare the ton for CASE. The obvious answer would be to remove a ton of AMS ammo, but I'm pretty sure that'd make the dual AMS run dry far too early.
    I'm also concerned about how small its ammo bins are. 2 tons of AC10, and 3 tons of LRM ammo don't go very far (at least not when my trigger-happy self is playing).
  3. The Verge
    just to add ammo and BAP. I did take out a ton of AMS, but really, you should be fine with 1 ton. Just keep running! 5-5 stars for the OP build.
