AS7-D-DC Silverback (1x AC20, 3x SRM6+A, 2x LLas, ECM, STD315)
Thread in 'AS7-D-DC' started by BravoLima53, Oct 8, 2013.
  1. BravoLima53
    BravoLima53 New Member
    This is my first post to Mech Specs and I am sure this build has been done. I use this build with great effect and have a pretty good KDR with it, last I checked it was 1.67, so I am pretty happy with it. It does run a bit hot so I keep my LLas on chain-fire to help manage the heat.
  2. Cthulu Jr.
    Cthulu Jr. Well-Known Member
    229
    One of the better brawling builds I've ever seen. Enough ammo to make the AC/20 worthwhile, Artemis SRMs are great all-purpose weapons, and LLas are quite possibly the best cost-effective energy weapons in the game right now.
    However, I would drop a DHS for another ton of SRM ammo-you only get 15 volleys right now, and it won't hurt your cooling efficiency enough for it to be a problem, as long as you don't overuse the LLas
  3. Blagg Zear
    This build needs to be faster & cooler:
  4. tfun90
    I'd been running the 'CQC' build, but a STD300 D-DC is slow to the point of being a liability. Not only would just about anything be able to run circles around me or track me down, it took forever to close range and get my SRM6+A's and MLas in range. Devastating if you could trick your enemy into getting that close, but rather ineffective otherwise.
    Theme: STD325 D-DC with ERLLas arms for ranged fighting and AC20+SRM for CQC.
    Flaws: A bit low on ammo and cooling, but by sticking to ERLLas at long range and AC/SRM for CQC, it should last long enough for a 12v12. 2 ERLLas isn't too shabby weaponry to be left with.
  5. enileph
    I don't think SRM4 requires +A, the grouping is good enough.
    I actually prefer the shotgun effect of SRM6 in this case, as it helps on hitting smaller mechs.
    This is my setup. LLas or ERLLas depends on mood.
  6. LT Satisfactory
    LT Satisfactory Benefactor
    815
    61
    +1 to enileph's version. I wish I could get art on the SRMs, but I find the reach of the LL/ERLL is worth it over running MLs with the art.
