AS7-D-DC Hammer MKII (1x AC20, 3x SRM6, 2x MPLas, AMS, STD350)
Thread in 'AS7-D-DC' started by Bilbo, Oct 26, 2012.
  1. Bilbo
    Bilbo Junior Member
  2. Michael
    I bet this thing just annihilates light mechs in the city!!!
  3. Bilbo
    Bilbo Junior Member
    Yes it does. Cicadas as well. Much fun playing this last night.
    I have a similar build for the Founders Atlas that I'll post later. It uses the gauss instead.
  4. JTBlack
    JTBlack Junior Member
    Greetings,
    First post , apologies for bare profile :) on my phone here ...
    +1 to this build what a beast.
  5. Michael
    Welcome to the forums!
    If you click "LIKE POST" you can +1 it without post whoring ;)
    You can also RATE THREAD (up at the top) if you really like the build and want to recommend it to others.
  6. FuzzyBunny
    FuzzyBunny MechSpecs Addict
    Bilbo. How does this one run? I've found that it seems to me like the 10 HS stock in the engine are regular and not doubled, even if you buy double. The ones added to the engine after and then put into the chassis seems to double fine. Does this feel like you only have 22 single heat sinks worth of heat efficiency, or the supposed to be 32?
  7. Bilbo
    Bilbo Junior Member
    It runs really cool in comparison to the same loadout with 23 HS prior to the patch. There are 14 Sinks internal to the 350 motor. Then Just 2 more left to place. I believe you don't run into the DHS issue if you change the engine after upgrading to DHS.
  8. FuzzyBunny
    Yeah I like your thinking on this. I'm going to have to try it tonight. Faster and cooler, sooooo nice. Thanks again Bilbo.
  9. FuzzyBunny
    Ran this build. Runs perfectly. I added an extra ton of AC/20 ammo though. Good build Bilbo!
  10. JTBlack
    Ran this build last night added 1 more ton of SRM ammo , performed the hero mech on the field by taking out the last 4 mechs whilst being the last survivor from what ppl thought i had no chance vs 1 Atlas, 2 cats with LRMs, HBK :)
  11. Turbo Corvair
    Turbo Corvair New Member
    I can't get this to work, I come up three tons short for ammo. I checked everything over and over, armor is right, upgrades are right... did something change since this was posted?
    UPDATE: Fixed! I didn't realize there was a command console in the head that I had to take out. Thanks!
  12. Turbo Corvair
    What did you guys sacrifice for one more ton of ammo? Armor?
  13. Turbo Corvair
    Loving this build. Can you guys tell me what kind of damage you are getting per match? Hoping for a benchmark to work with.
    Thanks
  14. Namwons
    Namwons Dispossessed
    you could probably squeeze another ton of AC20 by removing half a ton from each leg. (or a full ton)
  15. Namwons
    Im gonna have to give this build a try Bilbo, it looks beastly with the addition of artemis.
  16. Bilbo
    Bilbo Junior Member
    With the artemis, the SRMs act like the did before they were nerfed with more spread. The are pretty devastating again.
  17. Cutsman
    Cutsman New Member
    This looks like it runs awfully hot. Any reason for the AC-20 over a Gauss? Also, I assume the STD350 is for the 2 extra HS slots? The Endo is the only thing that keeps it within weight limits. I feel like this could be tweaked a bit more but I'm not sure, I'm at work and can't actually field test it yet. Will do that later tonight.
  18. Bilbo
    Bilbo Junior Member
    It's not too bad. The AC/20 saves another ton over the gauss, doesn't explode when destroyed, and I do my work at 200m or closer anyway.
  19. Broceratops
    Broceratops New Member
    Yep. Your revised version is what I use exactly, but I shave another ton of armor off to get another ton of AC/20. SRM6's are definitely back.
    As far as being a 0m to 200m brawler, I feel this this the optimal design.
    @ Cutsman, there really isn't many things you can do to tweak it because there will be both no more crit slots and no more weight. You could lose the AMS if you want and throw in another HS but I wouldnt recommend it. LRMs might be pretty meh now, but you do not need the extra HS either.
  20. Jaynen
    Jaynen New Member
    Trying this but I am unable to get another heat sink in the torso with DHS LT and RT are full of weapons CT has 2 slots besides the engine heatsink location. What am I missing?
