I edited change EPPC to PPC couse its much better believe me but the irony of ppc close combat like 90m dont do damage, but the bright side more shots lower heat so if you maintain 90m off the target you walop lots of dmg, but it's your choice you could use EPPC that guaranteed nose to nose damage or you choice PPC. Groupe1 : 2xUAC > Both Chain Fire Groupe2 : 2xPPC Some new SS of game:
Just keep biting the pillow. Any way, welcome to mechspecs.com! I would run your build closer to this. It doesn't add what I would want on their (missiles) to be a sizeable backup weapon the the 2UAC5 cannons. However, this configuration will get you going faster; with more armor; and with only a 1% heat loss, which is more than acceptable when you have 2x Basic's like I do.
Hi there, Yes indeed yours is little bit better , but i change weapons types and etc. not always play by this build, sometimes srm and LLs ac20, so when you make endo-steel you lose slots, (or later you would need to buy standard structure again) its pernament, so you can't change types of builds mix them or etc. like i can more varie so my is more advance in this way.
