AS7-D "Crusher" (1x AC10, 1x AC5, 1x SRM6+A, 4x MLas, AMS, STD325)
Thread in 'AS7-D' started by BRUTAL FURY, Dec 30, 2013.
  1. BRUTAL FURY
    BRUTAL FURY Active Member
    This variant has a super power! First note the loadout (I'll explain more below).
    Now remove the 4x medium lasers and look loadout again: max sustained DPS = 10.33 and colling efficiency = 103%!!!
    Look
    This means that you can shoot with the maximum damage without worrying about the overheat (except perhaps in very hot maps).
    Note: the 4 ML can be triggered very frequently too, of course! (17 DHS!!).
    It is possible that you consider shaven armor too much, for me is acceptable, but if you want more you should open remove anything ...
    Good killing!
  2. Blagg Zear
    Alternate "Speed+Armor+" Version:
  3. BRUTAL FURY
    The version of Blagg is well balanced and effective, however, the idea of the variant is the effect: "max DPS, never overheat" (for that is needed to meet the 17 DHS for the "cold guns", AC10, AC5, SRM6). It works like this: facing a opopnent in close combat when its reactor gets too hot, stop shooting your lasers, but keep firing their other weapons (AC10, AC5, SRM6), the pressure is very strong! I offer other variant too (by the way that I used more, I confess), is without AMS and without arthemis, but uses a larger engine SRD350 and has more armor. It follows below:
    Ty all.
  4. Blagg Zear
    For the last version you have my 5 stars! :)
    17 Heatsinks rox!
  5. Lan
    Lan Mech Wrangler
    1,570
    Any end of round result scores to post? I'm sceptical about three different ammo types even if the heat is very nicely managed. :p
  6. BRUTAL FURY
    Sorry, I had good results, but no amazing, not played plenty of time with him. Say however that despite 3 different ammo its operation is simple (in my opinion). Well, it would have been better to wait a good print, right (I used it more for pure fun). :D
