Artillery strike issue
Thread in 'MechWarrior Online' started by bart2o, Dec 27, 2013.
  1. bart2o
    bart2o Well-Known Member
    189
    I have bought and used artillery strike, and now i have an "empty" module that i can't sell and it's unusable in combat. Anyone knows what to do to fix this?
    edit: I misunderstood the description - this should probably belong to some other part of the forums.
  2. Michael
    Moved this to general
    Artillery and Airstrike modules are "consumables" which means when you use them they are gone. They have to re-buy them each time you want to use them. There are Focus Modules for each of these that are permanent but the attack modules themselves are used up and gone.
  3. Mr Everything
    Mr Everything New Member
    When you Puchase the Artillery Consumable, it is placed in one of you empty Module slots
    so it takes up the same space as any of your standard Modules
    (This might change soon is the word on the street)
    You will always have this Artiller strike untill you unload it or Use it in Live battle.
    (If you use it on the training ground it will not be used up.)
    Once you use it your Module Slot becomes empty again and you need to re-purchase another, till you use it again.
    I Seem to buy one every Match (LOL).
    Hope this helps
  4. bart2o
    189
    I know it's a consumable and it should be consumed. I bought an artillery strike once, fitted it into a mech, consumed it during a battle, and now I have a single artillery strike "empty" module that i can equip on a mech, but it never shows up ingame.
    Judging from the fact that I can't find anyone else with a similar problem, I should probably report it to PGI.
  5. Michael
    Sounds like a bug to me. Once an Artillery Strike or Airstrike is used it is GONE. There should be NOTHING in that module slot.
  6. bart2o
    189
    Yes, that seems like it. Thanks for replying anyway :)
