For the tonnage it is hard to beat an alpha of 48 without sacrificing ECM. With low armor and lots of heat you probably want to get in and get out, rinse and repeat. You may want to use the A legs if you want additional structure over a faster turn rate. If you are crazy enough to sacrifice ECM, here is your alpha of 55 with the C left torso:
