WVR-7K "Rock You Like A" (3x ML, 3x SRM6, 4x JJ, LE300)
Thread in 'WVR-7K' started by Darvos, Feb 21, 2018.
  1. Darvos
    Darvos New Member
    Been shredding with this build in QP a lot
  2. Falconium
    Interesting. Rare to see such a large Light Engine on a 'Mech this size, while also putting out so much hurt.
    Can drop a JJ and half-ton of armor for an extra DHS if it runs hot.
  3. Darvos
    Darvos New Member
    Still in the process of speccing up, but the heat management requires "monitoring", basically run full alpha till hot and either back off, or switch to SRMs only. Given the mobility options, it's not too hard to find cover, and I have only had one or two shutdown issues in about 35 matches. After speccing into -heat and some ops tree it seems to be minimalised. You don't want to have too much facetime in this anyway, 2-3 volleys at most before you will get fried by enemies for sticking around too long.
