WVR-7K "Bumper" (3x SRM6+A, 3x MLas, 3x JJ, XL320)
4.66667/5,
3 ratings
Thread in 'WVR-7K' started by E5Ky, Dec 18, 2013.
  1. E5Ky
    E5Ky New Member
    If you're going to use 3x 6SRM you really want the Artemis.
    Can drop to a 300xl Add extra SRM Ammo and a DHS. Will consider this once I unlock speed tweak.
  2. Dr.Gonzo
    Dr.Gonzo New Member
    I came up with the same build as your second variant, and I really love it! It's a perfect finisher with the mobility and the short range punch.
    http://i.imgur.com/wecZYXf.jpg?1[/img]
  3. Neolad
    Neolad New Member
    Really enjoying this variant. I drop the CASE though and shift the ammo to the CT. You'll likely burn through it long before it becomes a problem. Use the extra 0.5t for another JJ. 5/5!
  4. Aylek
    This can even go to zombie mode. Might try this now that SRMs are beastly again.
  5. Lan
    Lan Mech Wrangler
    1,570
    Quirks in November pass makes this a whole lot better still, I just dropped three games and averaged an easy 500, even on Alpine and Caustic (long range maps).
  6. Lan
    Lan Mech Wrangler
    1,570
    Quirks included, this is now the optimal weapons loadout.
  7. Stooge 3
    Stooge 3 Junior Member
    I found this build recently on my own and fell in love with it. Brawling in mediums is a personal favorite and this mech is a prime example of that exactly. With the new quirks this build is pretty dandy with those SRMs reaching out to I believe 323m. My build is closer to the OP's second varient except that I added some armor, JJ's and removed a ton of ammo. Ideally, the extra ammo would be nice but I prefer better heat management. Overall though 5/5!
  8. Motörhead
    The XL320 idea is nice, because you need speed, but with the quirks 1 more DHS and 5T of ammo are a must.
    In the XL300 version I'd even add a 6th ton
    If you want to use this mech instead of the SHD 2K you gotta use its strenghts, firing from more range (meaning you will miss more and need more ammo).
  9. Motörhead
    The energy range quirk it's pretty amazing too for being general, if someone has SPL range module, he could try this, I bet it would do amazing.
  10. ZnA120910
    ZnA120910 New Member
    So I'm having an issue. My build is *exactly* like the OP's (except I'm sticking with the XL275), yet I have a ton left over and I'm noticing no "dynamic slots" in my fit (In fact, I have zero slots left, but a ton of weight). I have Endo-Steel equipped, but I don't think it's doing what it should, or it's bugged.
  11. Motörhead
    You probably have ferro fibrous armor too, you need to remove that.
  12. Riscy
    Riscy Benefactor
    156
    I like this build. Had a couple of great rounds while leveling. But please drop CASE in XL engine mechs, it is a waste of time. I agree that SRM6 always needs Artemis, I ran without a few rounds and the lack of focus makes it a problem unless you hug face.
  13. HctPeace69
    HctPeace69 Well-Known Member
    204
    44
    [​IMG] Solid build fo sho. Packs a nice punch, good maneuverability, durable for an Xl engine. No basic skills.
