WVR-6R "Punch Drunk" (1x AC10, 3x SRM4, 1x MLas, 3x JJ, XL280)
1 rating
Thread in 'WVR-6R' started by LT Satisfactory, Dec 18, 2013.
  1. LT Satisfactory
    LT Satisfactory Benefactor
    815
    61
    Been trying this build in my quest to find the right 6R build. With the splat of SRMs, I wanted to get a ballistic with a similar cooldown to put my time facing the target at a minimum before shielding with the left arm or going back in cover which leads to the AC10.
    I can't decide if the lone ML is worth it or not as this goes against my original design principles so I've been going back and forth with picking up more speed (and armor) in it's place:
  2. E5Ky
    E5Ky New Member
    Given its a head mounted Laser point. I think its worth the ton of space as a back up.
  3. Big Rex
    Big Rex New Member
    I think the triple srm4 and head ML complement each other quite well. Put them in the same fire group, and it adds nicely to your srm alpha splat. Heat is already quite manageable on this build. Very nice.
  4. The Verge
    I think I'm going to try this out. I might like it, I might not.
  5. LT Satisfactory
    815
    61
    there isn't much to like about wvr's, so good luck. Knowing you, you'll prob want to lower the DHS more, verg and fit more JJ :p
  6. The Verge
    Well, I prefer the Wvr's over Griffins, so that's that.
    I only changed a few things, mostly ammo placement and JJ and a bit of armor. I think I will keep this build, seeing as this is the only Medium mech I have that I want to run the AC10 on.
  7. boods
    boods Active Member
    85
    This is a fun build. I tweaked it a bit to add in 3xSRM6 and a UAC5.
  8. Spheroid
    Spheroid Well-Known Member
    202
    You need more SRM ammo and less UAC ammo. I run the same thing and the Wolverine's bread and butter is SRM jump brawling.
  9. Aylek
    I love the combination of an arm-mounted AC10 and the punch of triple SRM4 on a quick, jump-capable chassis.
    Some changes are necessary, though:
    - people tend to go for legs quite frequently, so up your armor there and place your ammo elsewhere
    - this is a front-up brawler, so put s much armor armor to the front as possible
    Result:
  10. boods
    boods Active Member
    85
    I really enjoyed this build. I tweaked mine to add a LB10X, some more armor and an X300
    Edit: Fixed the Smurfy build to show LB10X ammo.
