Scouting WVR-6K "Poky Poky" (3xLL, 2xERML, TC1, XL300) + alt
Thread in 'WVR-6K' started by CarloArmato, Dec 25, 2017.
  1. CarloArmato
    1,731
    513
    This build is viable in most game modes, but it is better used on scout mode.
    With a +10% range, -10% heat generation and -10% laser duration, it's a beast around 500 meters range and it's very cool. Your job is to cripple or aim for components like you would do with any laser vomit build, with the big pro of having most of your weapons arm mounted and the wolverine already has crazy torso pitch degress: you can almost shoot behind you (no kidding), so you can even flee and keep on firing on whoever tries to chase you.
    It can deal with anything above 300 meters and it's a giant middle finger to ATM boats and somewhat good even to ERLL snipers / kiters.
    ALT: remove a DHS and fit an AMS for additional "U Mad U Jelly ATM boat?"
    Nekromanteia likes this.
  2. Lorgot
    Lorgot Advanced Member
    403
    72
    Maybe new tech conversion?
  3. CarloArmato
    1,731
    513
    LE is very appealing, but build will be hotter and if you lose the right side, there is almost no point to stay alive with only 1xERML. The same applies if you lose the left side: with minus ~7 DHS, build will become too hot to be anywhere sustainable, so IMHO an XL engine with better speed and cooling seems the best.
    Nekromanteia and Shock like this.
  4. Lorgot
    403
    72
    Fair enough
