Invasion WHM-IIC-BL "Minor Delete Button" (2xcLPL, 2xcHLL, 1xcERML, cXL380)
1 rating
Thread in 'Bludgeon' started by CarloArmato, Feb 22, 2019.
  1. CarloArmato
    1,951
    585
    Lighter version of b33f's delete button
    Also, consider b33f's video was pre-patch and pre HLL nerf and DHS rework, so you must be a bit more shy and carefull, 'cause you alpha strike isn't that great now... In fact, this build is more likely a filler and a C-Bill farm rather than a top tier / competitive build.
    Don't alpha strike: to avoid triggering ghost heat, fire 2xcHLL then everything else.
  2. Mako275
    Mako275 New Member
    I've been using a slightly different version of this swapping the cERML for a TC1.
    Call it the Backspace. It does alright. Have to stay off the front but when you're this fast you tend to be the first assault somewhere. I've had the most successful games hanging out in the 2nd or rear front line. Using the range to burn people.
  3. Imunesky
    Imunesky New Member
    just build and really en joy the heat :D
