I plan on using a similar build to this. I'll post it in the morning if nobody else has by then. Just a piece of constructive criticism though, I don't think this build will be Skirmishing much of anything at 64.8kph. You generally want to push closer to 80kph for skirmishing. However, I see it being a mean brawler!! And an important piece of information: You seem to leave free tonnage when you could still add armor. Make sure you max that out so as to not confuse any players looking into your build. Leaves them feeling incomplete.
Personally i would use something like this. With 6 Mpl its way too hot. Also I think that 3 tons of SRM ammo are enough for most matches. Andamar
4/5, Got to play with a slightly tweaked version through basics this morning. I swapped out DHS and a half ton of armor for an AMS and 1t ammo. Overall, very satisfied with the 'mech and the build. Very fun brawler! I fire my MPLas in hemispheres and often use the SRMs on chain fire to help maintain DPS and heat management.
Pochatchu vs Enileph... Tried both, sorry Poch, but Enileph's is more superior in everyway.... Enileph perhaps THIS should be Ferrus Manus instead?
Actually I was thinking about that, but he posted it first, so mine is only a variant. But yeah this deserve the The title of Ferrus Manus
Same idea as enileph. But by swapping to mlas and srm6s the engine can be stepped up and alpha steps up aswell. Cooldown and duration do suffer though. But when you are near overheating and need to rely on a weapon system for dps, the heavier srms should be better. Another variation, dropping arm mdpls, allows for engine step up and mounting of Artemis. The srm6+A will improve pinpoint, keep with the better sustained DPS plan and arms can still be used as shields. The finale, std engine speedster. Drop Artemis, get std320. Same advantages as the other version, sans Artemis. This one just takes speed over tight spread.
This build looks potentially interesting. Here's my take on it: _ A little hotter than I typically like, but looks like it could be a mean knife fighter. <edit> - confirmed, super fun and effective. Fully skilled the heat isn't so bad. Easy to manage high/low hardpoints between the MPL's and SRM6's.
