VND-1X "The Nagger" (1xER-PPC, 1xLRM15, 3xMG, 3xJJ, XL235)
1 rating
Thread in 'VND-1X' started by Baradul, Oct 18, 2016.
  1. Baradul
    Baradul Junior Member
    The Vindicator VND-1X may not seem that powerful but if you utilize his hardpoints and quirks the right way it can be devastating on the battlefield. His main disadvantage is the low engine cap and the awkward hardpoint distribution. It does not seem to fit any certain role. But if you take a closer look you will see that his quirks enable him for a very interesting playstyle.
    In the first phases of the game you stay back and lay support fire. Try to reduce as much armor as possible to help out your team and make the later phases easier for you. Once the brawl begins you can go in and wreak havoc with your triple and heavily quirked machine guns. These weapons are excellent finishing weapons. If the enemy has stripped components you can destroy them (and any equipment in it) very easily.
  2. Hotdook
    Hotdook New Member
    The VNX-1X is such a tank, especially with the quirk system. It's armor rivals many heavies and even some assaults. The jump jets when used, allow the vindi to use its legs to tank some of the damage as well, spreading the damage across components. One thing I would do is drop the engine enough to put a small or medium laser in the head. With so few hardpoints, it makes sense to take advantage of all of them.
  3. Hotdook
    Hotdook New Member
    A Solid post with philosophy of use, explaining the merits of the build.
