Solaris VND-1X "The Best of the Worst" (1xMRM40, 3xHMG, 2xSL, LE225) + alt
3 ratings
Thread in 'VND-1X' started by CarloArmato, Apr 19, 2018.
  1. CarloArmato
    1,677
    496
    165
    Probably the tankiest and highest DPS build you can achieve in the 7th division
    Ballistic Cooldown− 15 %
    Energy Cooldown− 20 %
    Energy Heat− 20 %
    Heat Dissipation+ 7.5 %
    Machine Gun Rof+ 30 %
    Missile Cooldown− 25 %
    Ppc Velocity+ 20 %
    Base Armor (CT)+ 20
    Base Armor (LA)+ 16
    Base Armor (LL)+ 17
    Base Armor (LT)+ 18
    Base Armor (RA)+ 16
    Base Armor (RL)+ 17
    Base Armor (RT)+ 18
    You can tank and spank at the same time.
    Simply push the enemy to get closer and keep on firing the MRM40 until you get close enough to have little to no spread at all. HMGs with +30% RoF are very scary up close and can also crit ammo: this means you can go for legs instead of CT.
    ALT: replace the additional DHS, swap half ton of MRM ammo for JJs / JJ + better engine / other. You can also swap SL for ERSL. Fine tune it as you like.
  2. Excalibaard
    4,523
    1,000
    Bradtothebone, top player in D7, uses this build with 78 wins 0 losses. It's also the mech I'm looking to pick up the most (already since baradul had a video on a similar build)
  3. Aylek
    Clear winner of the 'Capt. Obvious' prize for Div 7. No surprise for my team as we have used this thing in MRBC scrims and drops for quite some time now.
  4. anamiac
    anamiac Well-Known Member
    140
    Looks solid. I was thinking 'but what if it had flamers', then I realized it was a solaris build.
