UZL-3P "Harbinger" (2xUAC5, LE250)
4 ratings
Thread in 'UZL-3P' started by Unmarten, Sep 7, 2017.
  1. Unmarten
    Unmarten New Member
    This is a build with moderate damage output and no heat problems.
    You should skill survival, enhanced UAC and magazine capacity.
  2. Ruludos
    Ruludos Benefactor
    88
    51
    I believe that this is one of the best ways to run the Uziel-3P. The low hardpoint count and general fragility of the chassis means that the mech is best suited as a second-line fire support mech, and the arm-mounted ballistics are high enough to use the UACs effectively. The only thing missing is a few jumpjets or energy backups, but at fifty tons you can’t have everything.
  3. BeefSupreme2018
    BeefSupreme2018 New Member
    Good tough mech with nice DPS.
  4. Trippton
    Trippton Active Member
    57
    The UZL-3P(C) variant of this mech comes with Ferro Fibrous armor, which gives you an extra ton to play with. You can either keep the 2 JJs the mech comes with or add some more ammo.
  5. Malcolm Tudor
    Malcolm Tudor New Member
    Put together something similar recently. Went with a smaller engine, lt225. 2x uac5, 2x er med, 2x jump jets. Gave up a little top speed for extra ammo and the lasers.
  6. RattlerGUNZ
    RattlerGUNZ New Member
  7. Lorgot
    Lorgot Advanced Member
    403
    72
    This should be a thread of its own
    Dagonus likes this.
